Discussion topic: Sky Premier League
This message was authored by: Lennie84
Sky Premier League
Sky Premier League channel looks like a kalaidoscope. No picture, no sound, then have to switch off SkyQ box as it jams up the system.
Phoned Sky, automation said all fixes are here. I can find none.
Any clues ?
Re: Sky Premier League
Hi @Lennie84   Do you mean that the picture is pixelated? This would indicate a problem with your dish.
Having a problem with your TV signal? | Sky Help | Sky.com | Sky Help | Sky.com
Avatar for Lennie84
Level 0 icon
It is only on this channel
Every other Sky channel works fine... sorry, ITV is also the same
@Lennie84
If it is a satellite signal issue, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels
