Discussion topic: Sky Minibox
This message was authored by: Sunny691
Sky Minibox
Message on screen suddenly "This screen does not support HDCP.  Try reconnecting your HDMI cable or use a different screen."
Have done usual checks and replaced HDMI cable yet still getting same message.
Re: Sky Minibox
Hi @Sunny691
Did you reconnect the HDMI cable at both ends
Also have you tried rebooting your min box?
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the mini box (Amber led).
Also try rebooting the Television by disconnecting the power lead for secs.
