Discussion topic: Sky Mini not connecting to Sky Q
Message posted on 05 Sep 2023 10:22 AM
I have been having connection issues between the Sky Q and mini. The Sky Q was connected by wifi, the Mini by ethernet cable and I had a Sky Booster on BT Wifi.
I have now changed to Zzoom Fibre and added a Deco X50 wifi 6 Mesh and the Sky Mini now loses connection to the Sky Q.
After some MR104 errors I have removed the Sky Booster and both Q and Mini are now ethernet connected directly to Deco hubs but the mini still drops out and reports a connection issue with the Sky Q box even though the internet is very strong and ethernet connected.
How does the Sky Q communicate to the Sky Mini?
Should I turn off the Wifi connection in both Sky Q and Mini via 0,0,1 select?
If I turn off wifi on both Sky Q and Mini how will they communicate as they are quite far apart?
Thank you!
Message posted on 05 Sep 2023 09:10 PM - last edited: 05 Sep 2023 09:11 PM
Re: Sky Mini not connecting to Sky Q
Thank you!
Hi @WoodyMMIX
As you have both Q boxes connected by Ethernet to the same Network you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router. Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Message posted on 05 Sep 2023 11:34 PM
Great. I'll try that.
How will the Sky Q communicate with the Sky Mini when the Wi-Fi is turned off? They are quite far apart.....
Message posted on 06 Sep 2023 07:36 AM
You said you'd connected them via ethernet to Deco nodes - they'll communicate through that wifi mesh (though they will think it's ethernet)
Message posted on 06 Sep 2023 09:04 AM
Oh - I didnt know they could do that.
Thanks for explaining.
