Discussion topic: Sky Mini box freezes
Message posted on 25 Sep 2024 12:31 PM
Sky mini box says all connected and tests all good on My Sky, but the picture keeps freezing or blue screening at all times of day.
Message posted on 25 Sep 2024 02:36 PM
Re: Sky Mini box freezes
Hi @Higgo.
Reboot the mini as above.
