Discussion topic: Sky Mini - Ethernet
Message posted on 24 Jul 2026 05:09 PM
Sky Mini - Ethernet
We've just gone back to to Sky Broadband (max hub), we've got Sky Q main box which connected viabEthernet cable. We've also got a Sky mini box at the end of the garden which is also connected via Ethernet to the Sky max hub but we cannot get it to connect. Previously ran the same setup with Virgin but the mini just won't connect. Keep reading to ignore the WPS step but it just fails and if we try it it's trying to connect over WiFi so joins and then fails two seconds later.
Message posted on 24 Jul 2026 05:46 PM
Re: Sky Mini - Ethernet
Hi @LW121 Just to clarify, both Main box and Mini box are connected to two ports on the Sky Max router.
Message posted on 24 Jul 2026 08:00 PM
Yes both
Message posted on 24 Jul 2026 08:44 PM - last edited: 24 Jul 2026 08:44 PM
Hi @LW121 Have you turned off all WiFi on the Sky Q boxes?
