Discussion topic: Sky Mini Box Losing Connection
This message was authored by: stonemanash
Hello,
Sky Q Mini Box keeps losing connection, TV and picture continually stutter and drop out meaning the box is frustratingly unwatchable.
I have tried resetting the box, resetting the connection, I have tried all steps advised and no luck.
Please help.
This message was authored by: ThePope27
Re: Sky Mini Box Losing Connection
Hi,
If you are with Sky Broadband try the below
Reset your network connection on the box again and when it says to press the WPS button on the Main Sky Q box, instead of doing that try holding the WPS button on the router instead.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for stonemanash
Appreciate your support.
I have just tried and to no avail.
The box continues to freeze and stutter.
I would give sky a call and ask them to send out a Sky Q booster,
It will sit half way between the Main Q box and the Mini box to boost the signal
Once you have it use the below instructions to set it up
https://www.sky.com/help/articles/sky-wifi-booster-setup-q-booster
