Discussion topic: Sky HD channels
This message was authored by: Scott3434
Sky HD channels
Iv got sky HD on SkyQ sports and movies work but sky Atlantic etc all say I need subscription to watch these programs in HD but I 100% have these, tried all the normal stuff tried a callback in skyq card
Re: Sky HD channels
hi @Scott3434
Do you have SKY HD & not just the SKY sports HD add on ?
If you don't have the SKY HD (i.e. non sports) then:
As the default download quality is set to HD (high Definition) not SD then when you try to download and watch from SKY Atlantic & others you are prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
