1
This discussion topic has been answered Discussion topic: Sky Essential TV
This message was authored by: CDo6
Sky Essential TV
I am new to Sky and waiting my sky to be delivered, can I record from Sky Essential TV or do I need sky Q?
This message was authored by: nigea99 Answer
Re: Sky Essential TV
hi @CDo6
If you have ordered SKY Stream  (or Glass)  with SKY Esential TV, then that is a stream only option - you can add shows to playlists and may be able to do some 'Cloud' recording  but recordings are not quite the same as on Physical disk that SKY Q
uses.
If you confirm that you have ordered SKY Stream, I will move this to that group & others can advise better regarding Cloud recording etc.  & using the system in general
hi @CDo6
uses.
