Discussion topic: Sky Atlantic
Message posted on 29 Nov 2024 12:33 AM
Sky Atlantic
Wy can't I view sky atlantic
Message posted on 29 Nov 2024 05:45 AM
Re: Sky Atlantic
Don't know. What happens when you try?
Message posted on 29 Nov 2024 06:22 AM
Re: Sky Atlantic
I suspect you may be referring to downloads & being asked to upgrade
This can happen if you do not have the HD add on
If this is the case then, as the default download quality is set to HD (high Definition) not SD then when you try to download and watch you are prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
