Discussion topic: Singnal problem
Message posted on 31 Dec 2023 10:01 PM
Singnal problem
Hi most channels are coming affected satalite signal problem
Message posted on 31 Dec 2023 10:08 PM
Signal pr
Hi a lot channels there being signal issue there no channels coming I can't watch Hogmanay 2nyt live
Message posted on 31 Dec 2023 10:10 PM - last edited: 31 Dec 2023 10:11 PM
Re: Signal pr
Probably an issue with your dish.
Check all the connections but you may have to call Sky to get an engineer to check but I don't think they'll be there by midnight...
Message posted on 01 Jan 2024 05:36 AM
Re: Singnal problem
@Kingali123
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
