Discussion topic: Signature Package
This message was authored by: VWR1
Signature Package
Since I can watch only one channel at a time, how do I reduce the cost of my Signature pack by trimming channels in the package?
Re: Signature Package
@VWR1
Everyone can only watch one channel at a time… but
To remove part of your Sky Q/+ TV package you will need to contact Sky and give 31 days notice. Be aware if you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another discount.
Select ‘Need more help’ at the bottom of the following link which will lead to contact details.
https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ The link may include an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ it’s only by calling Sky Ireland or writing in.
It's not clear what you're asking?   The Signature pack is fixed - you cannot change what it consist of.
So you can't remove Sky Max from it for example (with a corresponding reduction).
