Discussion topic: Signal issues
Message posted on 09 May 2024 03:08 PM
Signal issues
Tried all advice given.
Cannot get signal from dish to TV.
Cannot remove ariel cables at the back
Message posted on 09 May 2024 03:14 PM
Re: Signal issues
Which error message are you seeing?
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
