Discussion topic: Signal issue
Message posted on 03 Nov 2023 09:34 PM
Signal issue
My main box is not working and my sky q mini boxes keep coming up with no signal or connectivity issues
Message posted on 03 Nov 2023 09:54 PM
Re: Signal issue
Hi @Danwhitetm
What is the issue with the main Q box?
Message posted on 03 Nov 2023 09:57 PM
Re: Signal issue
Picture and sound cutting in and out
Message posted on 03 Nov 2023 10:06 PM
Re: Signal issue
Hi @Danwhitetm
Try a Reset Settings in the main Q box hidden menu.
