Discussion topic: Signal issue on some channels
This message was authored by: D68B
Today for some reason I am getting a "This channel is currently affected by a problem with your satellite signal" message on virtually every Sky Channel but not on a consider number of others ie BBC, ITV, 4, 5 Gold, etc.  I've switched the box off and gone through the settings checking scenario as suggested online but no joy.  Any ideas please?  It was fine yesterday.
Re: Signal issue on some channels
@D68B
”No signal” messages tend to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
When you see a “no satellite signal” error message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️very heavy rain or
▫️snow on the dish/LNB
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 adverse weather can affect the satellite signal and following such events wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
