Discussion topic: Signal breaking up when recording on Alibi channel
Message posted on 23 May 2023 04:20 PM
Message posted on 23 May 2023 04:24 PM
							Re: Signal breaking up when recording on Alibi channel
@Marian+H When you watch the albi channel live are you having the same issues??
“Trying to help improve sky glass”
Message posted on 23 May 2023 04:29 PM
At the moment, I'm just getting the message, " no satellite signal".
I don't usually watch the channel live.
Message posted on 23 May 2023 04:37 PM
I would try powering of your box for a few minutes,while it's off check the lnb connections at the back are tightly screwed in,also give the viewing card a light wipe with a dry lint free cloth,failing that I would suggest a call to sky as your dish may have slightly moved
Message posted on 23 May 2023 04:45 PM
Thanks, I will try these suggestions.
Message posted on 06 Sep 2023 10:08 PM
I've had exactly the same issue live or when recording. It's incredibly frustrating!! I've had the dish checked and even the non HD alibi channel won't often load - it varies but is rarely available. Has there been a frequency change or something? I've checked alll connections and followed all instructions. Note. I'm on a sky HD box.
Message posted on 07 Sep 2023 07:41 AM
According to satexpat.com, Alibi HD is on the same transponder frequency as ITV Meridan HD and ITV London HD. Do those work ok?
