Discussion topic: Should program info banner timeout
This message was authored by: debbie1285
Hi
Should the program info banner timeout after 5 seconds on sky q. Mine stays on until you press back up. On the old  sky+ it used to timeout automatically.
Re: Should program info banner timeout
Yes, a box reboot often sorts minor gremlins.
