Discussion topic: Shortcut to current channel on guide
Message posted on 19 Aug 2023 03:12 PM
Is there any way that I can shortcut to the channel I am currently watching on the guide rather than choosing home, tv guide and then scrolling to the channel. I remember this being possible in a previous box but haven't figured it out yet (if possible) on Sky Q.
Message posted on 19 Aug 2023 03:13 PM
Re: Shortcut to current channel on guide
@sboy68 You can enter the channel numbers using the remote 101 for BBC 1 HD etc.
Message posted on 19 Aug 2023 03:16 PM
You can also set up your favourite channels. You can set up to 99 of them and then just press one or two numbers for the channel ie; 3 for ITV1.
Message posted on 19 Aug 2023 04:01 PM
It is possible on Q @sboy68
but not necessarily a shortcut.
If you press Select on the remote to bring up lower info pane and then keep scolling right to the end you end up at the TV Guide. Select this and you enter the guide at the current channel.
