Discussion topic: Shared mini box ,in holiday cottage
This message was authored by: Deethomas1
I'm stopping at a holiday cottage and there is 3 mini boxes between the 3 cottages ,I was just wondering if I looged into netflix will the other cottages be sharing my netflix on the boxes aswell as it's all on the same WiFi net work many thanks dave
Re: Shared mini box ,in holiday cottage
Hi @Deethomas1
Even on the same Networkyou would need to sign in on each box separately.   So no;  the other minis will not see your Netflix details.
However remember to completely sign out of Netflix on the mini when your are finished.
This message was authored by: bob1234
@Deethomas1Netflix is not a problem however if there are 3 Q mini boxes there is a problem as only 2 can be used simultaneously.
