Discussion topic: Setting up sky q mini after reboot
Message posted on 26 May 2024 04:45 PM
My skyq mini has been working fine. Had to reset password on router(BT), now cannot complete setup on thr mini box. It gets to the screen "when thr screen goes blank press home button." But nothing happens when i press thr home button. Have tried several reboots/resets/power cycles.
the remot is working as i can do all of the setup until this screen.
Message posted on 26 May 2024 06:04 PM
							Re: Setting up sky q mini after reboot
What happens if you press the power button on the box?
Message posted on 26 May 2024 06:55 PM
It just turns off 😕
Message posted on 26 May 2024 07:11 PM
Hi @Chrissky123
Reboot the mini as above.
Message posted on 26 May 2024 08:43 PM
@Chrissky123 wrote:It just turns off 😕
When the screen goes black, the power button should go orange. So when you then press it, it goes red?
