Discussion topic: Setting up box
This message was authored by: Melissasturmey
Setting up box
Hello, i ordered sky yesterday. I booked for an engineer to install, but i just wondered if i could do it myself? Im moving from virgin to sky.  Or is it wires etc.
Also my box is due to be delivered today, am i able to plug that all in today and use the tv or do i need to wait for the broadband box? Im just looking to speed up the process if possible. thank you
Re: Setting up box
@Melissasturmey
The engineer will bring the Sky Q box, any ordered mini boxes, remotes, cables and a dish with them on the installation date. A broadband router is usually dispatched to arrive a day or two before the Broadband is activated.
This message was authored by: Carole34
Re: Setting up box
Lucky you! I've got two deliveries from Sky but NO mention of an engineer or any other help related to the projected transfer to Sky on Monday
Re: Setting up box
@Carole34 what Sky system are you subscribing to is it Sky Q or Sky Stream Sky Q use a satellite signal to watch TV  Sky Stream uses your broadband to watch TV
Sky Q if you have never had it before needs an engineer to install a satellite dish/upgrade an existing dish. If you have previously subscribed to Sky Q they may send the boxes out and you can connect them yourself
Sky Stream is a plug and play system where you set it up yourself
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
