Discussion topic: Setting ua third box but remote not functioning at all.
This message was authored by Jebz67 This message was authored by: Jebz67
I am trying to set up a third box in my dining room. I have got to the part where I have to use the remote provided and it is not working or accepting the buttons pressed the middle dot in the centre of the arrow keys. It is part 1 of 4 to connect to WiFi.
Re: Setting ua third box but remote not functioning at all.
Hi @Jebz67
Reset your mini remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to get past step 1 of 4.
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
