Discussion topic: Series links arnt staying on
Message posted on 04 Jul 2024 07:51 PM
Message posted on 04 Jul 2024 08:06 PM - last edited: 04 Jul 2024 08:08 PM
Re: Series links arnt staying on
@Minimandy wrote:
So usually I add the series link and all is ok , it records every week without fail ......until the last few weeks. Am having to go into each day ans add the programme for recording . Then having to repeat this every week. The series link shows every time I add to record , but never follows to the next week. Its very frustrating as am missing my regular programmes. Any ideas?
couple of things to try
Try rebooting your main Q box ie
if that doesn't help
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
