Discussion topic: Series link not working
This message was authored by: Rob+Power
Series link did work but hasn't worked in 2024 . Series like coronation street and mafs you have to record every episode separately even when it has the series link is on showing the up and down arrows, ok when you remember but do miss episodes.  Anyone know a setting that might be causing it. I have taken the eco mode off ,powered down but still no joy.
Re: Series link not working
Hi @Rob+Power
The majority of series link failures or repeats are normally down to the Host Broadcaster coding incorrect link information.   Main line channels however don't often make mistakes.
You could try the following procedure.
First make a note of all your series links in ~Recordings - Scheduled.
Then first remove just the series link from each scheduled recording. ( Don't remove or cancel the recording at this stage, just remove the series link)
After you have removed all the series links then Cancel every scheduled recording.
Once the scheduled section is completely empty reboot the Q box.
Once the box is completely back up and running re add all your series links.
See how it goes.
Avatar for Rob+Power
No didn't work thanks though
