Discussion topic: Selected channels not working
Message posted on 31 Mar 2025 06:36 PM
Have had the sky box disconnected for 24 hours, on reconnecting not all channels showing (itv, channel 4, some of the U channels, alibi, comedy channel) but only selected. Tried help but no luck
Message posted on 31 Mar 2025 06:40 PM
Re: Selected channels not working
Any error message when you try to view these channels?
Message posted on 31 Mar 2025 06:42 PM
hi @Kelsley
The first thing to check is that both cables are fully connected.
Is it possible that one of the connecters has been knocked causing any of the thin strands of the outer braiding to come into contact with the central solid core wire ?
After that :
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Message posted on 31 Mar 2025 07:36 PM
This channel is currently affected by a problem with your satellite signal
Message posted on 31 Mar 2025 07:38 PM
@Kelsley
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 31 Mar 2025 07:39 PM
Message posted on 31 Mar 2025 07:49 PM - last edited: 31 Mar 2025 07:51 PM
Hi @Kelsley
When you disconnected and reconnected the two satellite dish cables you could quite possibly have bent the central copper conductor in the F connector.
The central conductor should be completely straight and central in the housing. It should not be bent or touching any part of the connector housing or screen.
It should also protrude by 2 - 3 mm out of the connector.
