Discussion topic: Second sky Q box
This message was authored by: Fireblade34
Second sky Q box
Second sky Q box in bedroom is connected to internet but we can't access sky tv
Re: Second sky Q box
Hi @Fireblade34
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
