25 Oct 2023 01:19 PM
Hi,
Recently the second box keeps losing connection, shutting off to a blue screen, and saying it can't be used.
It's never happened before, yet now it's almost guaranteed to happen any time we use it.
A woman from sky told gave me a number to call if it happened again, it's happened twice since, and she said it would take me to the Sky Tech team, who would arrange a replacement box.
However, I called the number and it took me here. So what is my next step please to rectify this issue.
I have unplugged, and plugged back in. My broadband is still with Sky, which was upgraded a couple of years ago to the faster speed package. Nothing has changed that would affect the signal. The issues have typically happened when the only gadgets being used, in the house,are the two TVs.
Cheers
25 Oct 2023 01:26 PM
@Jaymi2012 wrote:
Hi,
Cheers
Hi @Jaymi2012
Reboot the mini as above.
