This discussion topic has been answered Discussion topic: Second TV reception
Message posted on 22 Aug 2025 09:50 AM
What do I need to extend my Sky reception to a TV in anotherv room
Message posted on 22 Aug 2025 07:13 PM
I think I've managed it now. Thanks for your help.
Message posted on 22 Aug 2025 10:16 AM
Re: Second TV reception
Are you a Sky+ or Sky Q customer ?
Message posted on 22 Aug 2025 10:24 AM
Not sure. Nothing on my contract details states either if these. I note that on MySky there is an offer of Multiscreen for £8 pm so this may be what I'm after?
Message posted on 22 Aug 2025 11:49 AM
Now confirmed I'm a SkyQ customer.
Message posted on 22 Aug 2025 12:45 PM
Hi @DON36
You need multi screen and one mini box (they should come as a package )
The mini box is literally that - a small
black box which connects wirelessly to your main Sky Q box and plugs in to your second TV with an HDMI cable.
It will allow you to view your existing Sky channels (other than UHD) on a second TV
Depending on the distance between the main box and mini box (and the thickness of walls in your home) it will either connect perfectly or not.
if not then you might need to ask for a booster box to bridge the gap beteeen the two , but you will probably need to try without first to see how you get on.
Anything you have recorded on your main box can be viewed on your mini box (again, not UHD) . Anything you record from your mini box isn't recorded on that box as such - it sends a signal to your main box and records on there.
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 22 Aug 2025 02:56 PM
Thanks for your help - really useful. I found the Multiscreen area in "Manage your Sky TV" and "ordered" 1 mini box. The message accompanying this was "To add Multiscreen you need to checkout via your basket" but I've been unable to locate "basket". I checked "my orders" but nothing there so how do I take this forward?
Message posted on 22 Aug 2025 03:43 PM
Can you work your way through the virtual assistant to reach a person @DON36 ?
https://www.sky.com/help/sky-tv/sky-tv-q/q-my-account/q-orders
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 22 Aug 2025 04:32 PM
I've tried that but no joy. I keep getting the same response even when I specifically ask for account suppoty from a member of staff. I'll try the "Contavt us" route.
Message posted on 22 Aug 2025 04:40 PM
Do you have the option to upgrade from your Sky Q menu @DON36 ?
Go to your TV and your Sky Q menu. Then right down at the bottom you will see MySky
Press enter on there
Go along to "upgrades and accessories" and see if there is a section for "Sky Q multiscreen"
That will offer you some ways to upgrade if the option is there.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 22 Aug 2025 07:21 PM
That's great @DON36
Hope it connects ok 👍
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 23 Aug 2025 08:01 PM
Sky mini box received, installed & working fine. Thanks again for your help. The bit that was "missing" from the MySky site was referral/direction to the Sky store.
Message posted on 23 Aug 2025 08:27 PM
That was quick @DON36 😅
glad it's working for you.
Sky Q 2TB main box
LG CX6LA from 2020
