Discussion topic: Screen problem
This message was authored by: JuneH
Message posted on 01 Apr 2026 10:44 AM
Screen problem
The column on the left is not visible its like the screen is too small but obviously it isn't I've switched off everything and tried the usual things.
Find out more
Message posted on 01 Apr 2026 11:29 AM
Re: Screen problem
Sounds like a TV issue not recognising or understanding the incoming signal metadata. You've completely powered down the sky box and TV and started again?
Tried changing the output res on the sky box?
Message posted on 01 Apr 2026 12:08 PM
Re: Screen problem
Do you mean the screen seems stretched and things are cut off on each side? It may be the aspect ratio of the TV has been changed, if that's the case you would need to use your TV's original remote (not the Sky remote) to change it back to 16:9.
