Discussion topic: Screen keeps going blank after minute or two when sky q is in but can still hear sound, any idea?
This message was authored by: Swallowmead
Screen goes blank but sound still on. When switching back on the same happens after a minute or so,
This message was authored by: Doc5907
Re: Screen keeps going blank after minute or two when sky q is in but can still hear sound, any idea
@Swallowmead
You could try a Reset Settings in the hidden menu.
Scroll down to Reset
After the Reset you may have to re pair your Bluetooth remote If you use one.
Sky Q 1TB UHD
LG TV
Sky Mobile
