Discussion topic: Saying no satellite service
Message posted on 12 Jan 2026 04:35 PM
Im being told there is no satellite service and now can't access the Apps such as Netflix and Amazon Prime. This happened a few days ago and all was working fine before. It's not a building / weather issue. What can I do?
Message posted on 12 Jan 2026 04:46 PM
Re: Saying no satellite service
hi @JamesEllis
It is possible that the dish has moved or possibly a problem with the cabling.
The box requires a periodic 'keep alive' signal which is sent via Satellite, so it is likely this was due, thus causing the ability to use the apps.
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
