Discussion topic: Satellite
Message posted on 10 Oct 2023 11:01 PM
Satellite
Message posted on 11 Oct 2023 05:23 AM
Re: Satellite
@Tom233
In case you’re not aware, this is a customer helps customer forum. You aren’t talking to Sky Customer Services here. Is there a particular reason you need to know?
Message posted on 11 Oct 2023 06:18 AM
Re: Satellite
You can tell by looking at it closely
Q wideband LNB default has 2 outputs. Hybrid is longer and usually has 6 ina 2+4 arrangement. Old HD usually have 4 or 8.
Really ancient ones discovered in the Valley of the Kings can have 1 or 2 which is unhelpful when identifying them but if you have Q you have wideband or hybrid anyway.
Message posted on 11 Oct 2023 09:44 AM
Re: Satellite
So if I buy a freesat 4k, due to bills being too high, would my lnb work on it?
Message posted on 11 Oct 2023 10:51 AM
Re: Satellite
@Tom233 wrote:So if I buy a freesat 4k, due to bills being too high, would my lnb work on it?
If you're currently using Q then yes.
