Discussion topic: Satellite
Message posted on 12 May 2022 01:26 PM
Satellite
Hi I got sky q installed yesterday and I can only watch certain channels because the rest are saying no satellite signal
I've checked the plugs and leads and everything is in properly but nothing
Can any one help as I don't know what to do
Message posted on 12 May 2022 01:29 PM
Re: Satellite
hi @Lg2000
you probably will need to call SKY to get an engineer to re-visit
Do you have your own dish or are you fed from a communal system ?
Message posted on 12 May 2022 01:30 PM
Re: Satellite
I live in a block of flats so communal dish
Message posted on 12 May 2022 01:34 PM - last edited: 12 May 2022 01:35 PM
Re: Satellite
Unfortunately that brings up a slight issue.
The feed that is faulty is owned by & the responibility of the Building management & they probaby are the ones you should contact first.
They may, however, be reluctant to deal.
SKY should however be able to check the signal on all the transponders and provide you with a PDF report that you can refer to your building management
Message posted on 12 May 2022 01:49 PM - last edited: 12 May 2022 01:55 PM
Re: Satellite
@Lg2000 wrote:...I live in a block of flats so communal dish
This is very unusual because the Sky Multiple Development trained engineer should have run several scans in order to check the measured performance parameters of all the 65 satellite transponder signals that your Sky Q receiver requires, for example;
Did the Sky MDU trained engineer have to install a Unitron dCSS-422 Sky Q Plug-In adaptor in the central communal distribution cabinet that serves your flat, in order to provide you with a Sky Q compatible Single Cable Router (SCR) feed or was the communal Integrated Reception System (IRS) installation already ready for residents who had Sky Q receivers?
In view of how quickly this problem has surfaced I suggest that you ask Sky to schedule another Sky MDU trained engineer without delay.
Godfrey.
Message posted on 12 May 2022 01:51 PM
Re: Satellite
He tested the signal but it was fine but I had sky ages ago and I had no signal problems
Message posted on 12 May 2022 01:57 PM
Re: Satellite
Message posted on 12 May 2022 01:58 PM
Re: Satellite
I had sky Q
Message posted on 12 May 2022 02:13 PM
Re: Satellite
@Lg2000 It would save a lot of time if you can convince Sky to schedule an MDU trained engineer to return and run a full scan, which would enable them to then email a PDF file copy of that detailed test to you, in order to allow you to pass any clearly identified problems on to the managing agents who look after your communal block, if the fault lies with the communal IRS installation.
Signal Levels
o Fully data log all ports from the existing switch that will be used to provide signal and ensure all pass.
o Check the signal levels are between 65dBuV and 85dBuV from the existing switch.
o MER - >11dB
o bBER - minimum- 2.00xE-4
If the loggers show fails there is nothing you can do to rectify the fault. Export the logger as a PDF file and send to the customer via email so they can speak to their Managing Agent (MA) so arrangements can be made to have the block serviced.
Or, if the problem is a defective Sky Q receiver they should be able to replace it for you.
Godfrey.
Message posted on 12 May 2022 02:23 PM
Re: Satellite
There coming on Monday between 8am and 1pm
