2
This discussion topic has been answered Discussion topic: Satellite signal
This message was authored by: nickcosh
Satellite signal
Sky channels not working  saying no satellite signal but other channels ok an Wi-Fi good to iPhone iPad etc
Re: Satellite signal
@nickcosh
If you are seeing any kind of ”No satellite signal” related message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️it is currently raining very heavily (in which case see if it returns to normal when it eases.)
So check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
Additionally:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be GB News and CNN),
🔹 a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
@nickcosh
Additionally:
Avatar for nickcosh
Thank you. Now waiting for engineer visit
