Discussion topic: Satellite signal.
This message was authored by: Fidel+59
Satellite signal.
As I write I have picture on Sky Sports UHD, Sky Sports football,Sky Sports F1 Sky Sports Golf. The rest other Sports channels I get "This channel is currently affected by a problem with your satellite signal"
Any ideas?
Thanks.
N Jenkins
Re: Satellite signal.
@Fidel+59
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Avatar for Fidel+59
Level 4 icon
What  I don't understand is that half the Sky Sports are ok but the other half say signal issue 🤔
N Jenkins
@Fidel+59
Very common, as mentioned at the end of my reply above.
Avatar for Fidel+59
Level 4 icon
Yes my apologies. I should have read it more carefully. I live in a communal block of apartments so that could be the issue.
N Jenkins
@Fidel+59
So, are you connected to a communal dish? If so you'll need to report it your landlord or building management company so perhaps see if other residents are having issues as well.
Avatar for Fidel+59
Level 4 icon
Yes I am. I have put feelers out to neighbours to see if they have any issues but no repliey yet. I'll have to speak to the caretaker on Monday.
N Jenkins
