Discussion topic: Satellite signal issue
This message was authored by: ChadRyan
my sky TV satellite signal. What do I do because I am unable to watch live TV on my sky Q box what do I do? How do I resolve this issue please?
Moderator note: Amended post to better reflect subject.
Avatar for ChadRyan
Level 3 icon
Re: Hi
it says not satellite on my sky Q box how do I resolve this issue please?
Re: Hi
@ChadRyan
Are you seeing an error message? ”No signal” tends to be a message from your TV (in which case check the cables going to the TV).
A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Avatar for ChadRyan
Level 3 icon
Hi Re: Satellite signal issue
How do I leave feedback for sky Q to add feature on the sky Q box's please?
Re: Hi Re: Satellite signal issue
@ChadRyan
Sky are unlikely to add any new features to the Sky Q this far into its tenure.
Avatar for ChadRyan
Level 3 icon
how do i reset my sky q vt services in my account
Reset?
If the issue is with your Satellite signal then assuming it's your own dish they you'll need to contact Sky to get it checked.
