Discussion topic: Satellite lead
Message posted on 12 Jul 2025 10:11 PM
Satellite lead
Message posted on 12 Jul 2025 10:22 PM
Re: Satellite lead
@Robertjohnston wrote:
Satellite cable is damaged so it won't connect to alot of channels it needs replacing
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue.
Sky will replace your Satellite cables for a cost in the region of £65.
You need to contact them directly.
Message posted on 13 Jul 2025 06:59 AM - last edited: 13 Jul 2025 07:02 AM
Re: Satellite lead
"A lot" is 2 words
just my ongoing internet campaign.
You could also replace them yourself, likely to be a lot cheaper than £65 but dish position could well make that tricky.
If they got damaged inside the house you could replace that section. I wouldn't do that externally though.
