Discussion topic: Satellite issues
This message was authored by: Seekadeal
Satellite issues
Morning
I've nit been able to watch sky tv as everyone I switch my tv on it says The Channrl is currently affected by a problem with your satellite.   This is happening on all the channels. If started last night and it's the same today. I've switched on and off a few times,
can anyone help.
very difficult to get hold of anyone from sky !
Re: Satellite issues
@Seekadeal wrote:
can anyone help.
Work through this: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
...but you'll likely need an engineer to check your dish.
@Seekadeal
As it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
