Discussion topic: Satellite issues
This message was authored by: Lesley33
Satellite issues
Can't get some channels message says satellite problem I have tried all help guidelines and nothing some of the channels come back and picture is distorted
Re: Satellite issues
@Lesley33
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
