Discussion topic: Satellite Signal for my TNT Sports channels
This message was authored by: JeremyK85
hi My TNT Sports 1 channel is working fine but the Satellite signal is failing for Chanells TNT sports 2 , 3 and 4
All other channels are okay, can you help with this?
thanks
Re: Satellite Signal for my TNT Sports channels
@JeremyK85
A common issue with those channels I believe (I don't subscribe to TNT).
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
