Discussion topic: Sarason TV what remote control code
This message was authored by: WelshCottage
Hi all
does anyone one know the remote control code for a sarason tv, generic remote control works so maybe a generic code i can use. Thanks
JMO
Re: Sarason TV what remote control code
@WelshCottage wrote:
Hi all
@WelshCottage you could the vestel or try the other brands
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for WelshCottage
Level 2 icon
So I have tried about 30differnt codes (between other things!) still can't find one that works, as a generic remote control work for most things there must be a general
code that also works? All help appreciated 🙂
JMO
@WelshCottage the only other thing I can think of is to contact Sarason TV at the link below as they may know if they use some other companies tech and may be able to prove you with this information
https://sarasontv.co.uk/contact/
@WelshCottage @Laing1
The spec sheet suggests whoever they are, they probably aren't Turkish ; )
This message was authored by: bob1234
Probably best to phone them there is a UK phone number on their web site, it however looks a dodgy firm. One line T&C which are actually illegal as they can't say no refunds. Also the company number they give does not show on "companies house"
