Discussion topic: Samsung IR remote codes
This message was authored by: Simon365q
Does anyone know where can I find the Sky Q IR remote code for a Samsung QN90F? The on screen help has no TV models starting with a Q which is odd given so many Samsung TVs starting with QE.  There are plenty of old codes but none work. Thank you.
Re: Samsung IR remote codes
Hi @Simon365q   QN90F Is a series number, not a model number which probably starts with T. As it is a 2025 model so there is a good chance that it is not included, so just try something similar.
hi @Simon365q
I generally recommend customers to use the find it for me option as often the specific models are not listed and the codes offered usually work (often without needing go through all the codes)
This message was authored by: alessandro_s_it
The QN90F I just set up with my Sky Q (Italian, HUMAX) was detected by the Sky remote via the guided process as soon as I selected "Samsung" - no need for anything else.
On the other hand, the TV remote can't drive the Sky Q, and doesn't apparently know about that specific HUMAX decoder model.
