Discussion topic: SKY Q box constantly locking
Message posted on 18 May 2026 06:43 PM
Hi, really struggling with Sky Q box constantly locking up. Have the orange light on it but will not turn on. Unplug the power and it comes on. This is now becoming a real pain and requires hard reboot nearly everytime it is turned on
Message posted on 18 May 2026 08:53 PM
Re: SKY Q box constantly locking
Hi sky. I'm 48!!! Couldn't care less about receiving a bloody badge and no interest in collecting anymore . It would be great if I could actually speak to someone about the issue we are having with the Sky Q box
Message posted on 18 May 2026 08:58 PM
@Lee_pv wrote:Hi sky.
You're not contacting Sky directly here - it's primarily a customer helps customer forum (thus the badge system).
You can try a settings reset first:
Message posted on 18 May 2026 09:04 PM
Thank you. I just get keep getting directed here so gave it a go. Got a number which I rang for them. Obviously can't speak to anyone anymore. So got sent a text to this group which said could get an amazing ai can't remember the fancy of this person. But thank you I'll give it a go. I'm sure someone will answer when I get that fed up
ill just cancel and go down the route of everybody else. They will all of a sudden have someone available no doubt. But thanks anyway
Message posted on 18 May 2026 09:20 PM
No AI here, we're real humans...
If you want to cancel you'll have to contact them. Do not be tempted to withhold payment.
Message posted on 18 May 2026 09:25 PM
Thanks, but I won't be paying for a service that have to pull the table out a couple of times a day to reboot it
Message posted on 18 May 2026 09:31 PM
@Lee_pv wrote:Thanks, but I won't be paying for a service that have to pull the table out a couple of times a day to reboot it
It's up to you but withholding payment won't work out the way you hope...
Message posted on 18 May 2026 09:37 PM
Hey forget that box is locked up again but got a new badge 😩😂
