Discussion topic: SKY BOX not working
Message posted on 02 Dec 2023 01:40 PM
SKY BOX not working
Hi,
I have a pretty new sky box from yourselves.
however it has started freezing and then turning itself off. It whirrs for a while. It happened yesterday and I unplugged the box. It was ok after 5 minutes.
however it has happened 3 times already this morning.
can you help please?
rich
Message posted on 02 Dec 2023 01:59 PM
Re: SKY BOX not working
@RichardP2 wrote:
Hi,
however it has happened 3 times already this morning.can you help please?
rich
@RichardP2 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
