Discussion topic: Reset Sky Q box
Message posted on ‎23 Aug 2024 09:43 PM
Reset Sky Q box
My box is a few years old. Just recently I have to reset it several times a week. It always works after a reset but it's annoying having to keep doing thios.
Message posted on ‎23 Aug 2024 09:45 PM
Re: Reset Sky Q box
What reset are you doing @Billhammer ??
Message posted on ‎23 Aug 2024 09:48 PM
Re: Reset Sky Q box
Switching off at the wall for a while.
Message posted on ‎23 Aug 2024 09:53 PM
Re: Reset Sky Q box
OK @Billhammer
That's just a reboot.
