This discussion topic has been answered Discussion topic: Reset PIN not working
Message posted on 03 Feb 2024 02:09 PM
I just upgraded to a Sky Q box, and was annoyed to discover that the PIN is still a "feature".
My PIN from my Sky HD box didn't work.
The default 0000 didn't work.
The last 4 digits of my Sky account number didn't work.
The last 4 digits of my bank account number didn't work.
I can't reset the PIN in the Q box, because it's asking for the current PIN.
I've logged into My Sky and reset the PIN a few times, and powered the Q box off and on again.
But the new PIN number still doesn't work on the Q box.
Help!
Message posted on 03 Feb 2024 02:14 PM - last edited: 03 Feb 2024 02:15 PM
Help!
@spud71 the default pin number on Q is the last 4 digits of your viewing card
you can find your card number by pressing the home button scrolling down to settings then system info
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Help!
Message posted on 03 Feb 2024 02:26 PM
Re: Reset PIN not working
Ah!
The card number PIN works on the locked channels, but the Reset PIN screen says that it's the wrong PIN (and it also refuses the PIN that I reset the PIN to in MySky).
I guess that I'll just have to put up with this buggy "feature".
Thanks.
Message posted on 04 Mar 2024 07:06 PM
No help at all,I only wanted to speak to an advisor
Message posted on 14 May 2026 10:15 AM
got same problem want move anywhere put right pin numbers and nothing there to yes ?
