Discussion topic: Replacement optical cable
This message was authored by: Paty1
My dog chewed the sky soundbox optical lead what's the spec for new one or why to buy?
Re: Replacement optical cable
@Paty1
Should be a standard TOSLINK ('optical audio') cable.  Amazon Basics will do you one for about £6: spending more makes no difference to audio quality.
Avatar for Paty1
Thank you👍
