Discussion topic: Replacement Viewing card
This message was authored by: Dorny1
Hi , I received this message in regards to replacement viewing cards , how do I go about this and where can I access new one ?
Re: Replacement Viewing card
Hi @Dorny1
Have you tried refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
