3
This discussion topic has been answered Discussion topic: Replacement Sky Q Box 2025
This message was authored by: Jchin99
Hi
I have just sent off for a replacement Sky Q Box. My current one is a 2 Tb box. How do. Find out whether my replacement box is:
1. Also 2 Tb (or not)?
2. New or refurbished?
Thanks in advance.
This message was authored by: nigea99 Answer
Re: Replacement Sky Q Box 2025
hi @Jchin99
As @Laing1 says they replace on a like for like basis & probably all 2TB boxes (& even probably most 1TB) are now refurbished
When you do get the replacement make sure you take out your viewing card before handing over the old box.
Note Some 2TB boxes have a separate power supply - if you have one make sure you send it & check the new box (if ituses one it has a multipin connector rather than the Mains figure of 8   )   & if it needs a separate PSU make sure one is the box/ given to you
@Jchin99 wrote:
Hi
Thanks in advance.
@Jchin99 it should be a like for like swap so you should get another 2 TB box more than likely it will be a refurbished box as i doubt Sky have any new Q boxes now
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Remember all Q boxes are loaned to you for the duration of your subscription.  (And have to be returned if you cancel)
hi @Jchin99
