Discussion topic: Replace old Q box
Message posted on 07 Oct 2024 05:37 PM
Replace old Q box
Hi, how can I go about swapping my current Q box for a new one? My current Q box is over 4 years old, crashes frequently, and needs regular restarts.
Ben
Message posted on 07 Oct 2024 05:42 PM - last edited: 07 Oct 2024 05:44 PM
Re: Replace old Q box
Ben
Most Q boxes are that that age and older @BE13NNN
If you have issues best to contact Sky for an Engineer.
If necessary he will replace your Q box. Any replacement will be a similar age.
Message posted on 07 Oct 2024 05:46 PM
But when its working its fine. I was hoping to pre-empt a real problem that a restart doesn't fix. Its only a matter of time before it breaks for good.
Message posted on 07 Oct 2024 05:53 PM
Hi @BE13NNN
Try a Reset Settings in the Q box hidden menu. This may help
Message posted on 07 Oct 2024 06:21 PM
@BE13NNN wrote:But when its working its fine. I was hoping to pre-empt a real problem that a restart doesn't fix. Its only a matter of time before it breaks for good.
All Q boxes are lent to you for the duration of your subscription. That means they will replace faulty hardware without charge if you can convince them it needs it...
Message posted on 07 Oct 2024 06:39 PM
Ick. I was worried that might be the case.. I just want there to be a policy saying if you have old equipment you can request replacement no qualms
Message posted on 07 Oct 2024 06:45 PM
As I said @BE13NNN
All Q boxes will be a similar age.
With the number in circulation it's doubtful that any new boxes are currently manufactured as all are repairable.
