Discussion topic: Repeat messages about non problem
Message posted on 05 Jul 2026 07:18 AM
This message comes up every time I do a check on wi fi speed
There's a problem with your Sky Q,box , if it's not plugged in that's ok , if it is you may need some help connecting it .
I have reported this umpteen times but nothing is done to clear the Non Fault , the box Is fully connected with green tick , and is working 100% , it Skys problem not mine yet they seem incapable of fixing it !
Message posted on 05 Jul 2026 08:29 AM
Re: Repeat messages about non problem
@IanEA wrote:This message comes up every time I do a check on wi fi speed
There's a problem with your Sky Q,box , if it's not plugged in that's ok , if it is you may need some help connecting it .I have reported this umpteen times but nothing is done to clear the Non Fault , the box Is fully connected with green tick , and is working 100% , it Skys problem not mine yet they seem incapable of fixing it !
How are you checking the speed? Via the MySky app or through the Netflix Help speed check?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Message posted on 08 Jul 2026 11:07 AM
Hallo
speed check on My Sky app.
